I think the pages of ben's crap should be deleted...
This thread is where everyone chats and builds friendships... Its the main reason along with the thursday meets that qld is now one of the strongest sections, where it used to be the weakest... There are new people every week, which echos well when the club is set up in terms of paying members...
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
An idea that was brought up a while ago was a private section for the people who we know and trust...
I think we have enough people at the thursday meets to warrant a private section for talk about private activities and to also make life easier in organising the private events... Im sick of talking in code :)
PS: did i say private enough?
Strutto, other states have it and I think its worthwhile...
lol.. its just syndey mate.. but some from melb aren't much better I'll admit.
Pred - how come you were a no-show last nite?
I'm a girl.. may as well just admit it as that is what everybody has accusing me of :) nah, just too much driving in too many days.
Good to see another female join up... we had two new ones last night... they seemed to get along with everyone pretty well which is great...
Was a damn nice car too, she even has an after market diff... Would kick 90% of our asses down the strip as well. damn impressive...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
