  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Chaos, just had a more "in depth" disscussion and basically if you do a good job and dont piss fart around the job is yours once we start hiring, gonna post out an application form tomorrow so just fill it out and post it back to me with your currnt resume and I'll do my best.
we start hiring in two weeks so that is the earlest you can start, but do go quittin maccas yet, you might not like it here, it's pretty tough down in production, you gotta have thick skin or a really good sence of humor !!
Yes and I would touch them with a ten foot pole. Except I'd hit them over the head with that pole.
If you want cheap crappy work done, it's the best place to go. But if you want something done properly and don't wanna pay twice, go to somewhere that's got a GOOD reputation.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
