so im surely cruising next thursday :D
Your buying a Skyline? :rofl:
Good to hear...
No offence intended Platium but what are others thoughts on Non-Skylines attending our Thursday meets?
It seems to be getting a little out of hand lately...
I don't mind the odd import ... MR2T is probably fine, but Barinas, Commodores and Lancers is too far IMO...
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey peoples,
Just ordered my new yokohama V102 tyres ooohhhh they r sooo sweet i should have them on friday. They are pretty exxy ($350 each) but damn they will be good.
Bah! Should of gone the Semi Slicks... Oh well, will be good either way... Now you can come to the drags :rofl:
Good to hear...
hehe consider the mr2 as a skyline which was in a big accident lol, motor was pushed back and truck ran over the back seats hehe.
i cant cruise everyweek money wont let me :D but i go every now and than for some fun :)
yeh mr2's never really sold much, most was around 91-93 than died off after that, but theres gen4 3sgte's :rofl: in a different car but hey least the motor still lives on.
yeh watch a video last nite i had of a GT and GTS mr2 GTS was gen3 GT gen2 like mine but mine says GTS on the back :S so dont know wats going on, i still got airflow meter not map so i guess they screwed up but, the gen3 was .5sec quicker on the qtr mile gen2 5.6 PWR gen3 5.1PWR
zoix i wish i had a 400r bar, my TYPE M one is cracked from where i crashed into a gutter so eventually im gonna get a gtr one.
im only getting the rears in 235s........i wanted wider but my cheap rims arnt wide enough.
I love the tread pattern on them heres a link
http://www.yokohama.com.au/Tyres/tyre.asp?TyreId=26
I'm with strutto on this one it's starting to bother me too a little. I mean no offence to the parties involved, but it's getting a little out of hand lately IMHO.
my warning for the day..
http://www.skylinesaustralia.com/forums/sh...ad.php?p=752482
yeah.. seem what happens when you plan something good :rofl:
Well considering the amount of acutal requests for details for this thursday, other than the list i sent to. Going to be a fairly lowkey one. Which is fine with me.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
