  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
IF of course its true before they confiscate ur car ill swap bonnets with u, and ur clear indicators :P
Hey I already have dibs on the bonnet, but you can have the clear indicators :D
what you should do is swap your Auto box for the manual box :D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
