  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
mine doesn't seem to stick to the road as well as yours was. Where you were fanging ahead, if i pushed it i would'a lost it, so i had to hold back.
Thats cause you are running those big 255's and he has the stock rims, he has much more grip than you :D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
