  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i only got 235's and 17s.. not massive..
crappy tyres though.. but it doesn't seem to be that, its just the whole "sit" of the car feels weaker than it should. Its hard to explain.
I was only joking ;p
has the car been in a big accident that you are aware of?
(apart from the ones you were in)
yeah i don't get that.. because when we stopped halfway up the mountain.. i remember talking to him, saying yeah, its fine to have cars with balls to keep up, but its those slower cars and/or that handle badly are the ones that are becoming a concern. the mirage was turbo'ed anyhow..
I'd thought he already had read it? hmm
Seems phat mirage has cracked the shits and left the forum... did i miss something?
Oh, he drives a mirage and took offence to the no non-skylines thread... interesting concept
Saw that, hmmmm
He is a nice guy ......... pity
now he may never make the upgrade cause he thinks we are elitist snobs
well thats the thing.. i got over the whole "skylines are so great" ages ago.. and hell even bored of it a little so its good to have something different. FWD + turbo is always good for mountain runs (well thats what he did say he'd built it up for). hopefully he comes back.
That's kinda why I don't really have any objections to other forum members who don't have skylines joining in on the Thursday event.
Big Skyline event cruises are a different story and people just tagging along in their "whatever" because they're mates of someone who is a member is a no go
then it was smooths idea to to the whole fully sic new SAU flier body kit to owned :D got some great pics :rofl: at least he has some to hand out now :rofl:
That was my idea :(
Oh wait... no Smooth aka Matt (not Charly nor James (parking lot joke sorry)) thought of it... yeah thats right... Matt...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
