  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
between 250 to 300seconds, to get the bottle refilled at a shop is normally about 55 bucks, but my dad gets the really big bottles for me for free from his company and i fill it from then, not sure how many fills to a big bottle yet but the big one costs 400 bucks and that medical grade stuff.
sweet as, cya tomorrow dude, im still killing time waiting for stupid timezones, zimezones are the worst idea, earth should be flat day time is day time everywhere life would be much simpler part from the falling off the edge bit.
