  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nah that was her, we got back together, shes in france for another 3 months, id go see her now but uni and shit, told the parents i ditn want to go to uni this year cause of this reason and the fact i wanted to work but dad said he'd make my life hell if i didnt go. Meh nothing i can do now i suppose.
only 3 things in my entire life ive done that have gone against my dads wishes, drugs, he soon fixed that, NOS, and V8, he eased up now that im 18 but still expects me to do what im told within reason while i live at home, not always bad but not always good..
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
