  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hahahaha, some guy didnt believe me when i told him mine was non turbo, "bullshit all them rice boxes are turbos" he said, he was just pissed it beat him
guys thinks i'm nuts when i told them i had a rb25de in my car...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
