cyrus try using araldite ( i think thats how its spelt) it should bond better, and perhaps sand the paint back to the plastic in a few spots under the S so you get a good bond with the plastic and not just the paint,
Yeah just have to be bothered getting off my ass and going and buying some, and had a look in the guide holes and ther is not too much paint in there so just gonna fill it up and squish the badge on the top, that should be way more than enough to keep it on :D
But thanks fo rthe tips, muchly appreciated :D
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
dial up is frustrating when in postwhore thread :D
anyhow -
my car is making a noise from the rear passenger side
not a wheel bearing noise it isn't a metal sound - more like a squealch/squeak
think there are 2 noises as 1 stops when handbrake is slightly on (prob pads are glazed) but the other noise is louder
driving me crazy
he he he you are asking the wrong person, i am mechanically challenged :D but can do some searching for ya, adsl rules!
:D Hey if that is what is going to be happening next visit to 19th, you can count me out, fighting is for losers because that is all that everyone ends up as!
Bout your sig, damn hate to se the gravel rash on his shins, and I've done way stoopider thing than that!
nah i good - have my moments for sure but guess i got shy all of a sudden
little sister was stressing me out a bit too - she left for bris sth side round 3/4pm an hadn't called to say she home (bus an train with 2 male friends of hers)
oh - nice driving yesterday by the way - crazy mofo
that link sounds exactly the same too
Girlie - ahh its ok .. i felt real bad like i had done something wrong, you just went quite on me all of a sudden :D .. but as long as your alright then thatc ool :(
oh yeah that was bad driving by me girl, just as i kicked the ass out my windscreen fogged up .. so i had to back off because i couldnt see where i was slide too :D
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
