  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
aaa ok, so buy an after market thing to fix the limiter then?
Probably better.. although i've heard of people cutting wire 56 or whatever it is and no probs.. maybe they have already disconnected the hicas though.
mine has no cut but when i pulled most of my interior apart i couldn't find any separate device. opened up the ECU and nothing weird in there either. So not sure how its being done in mine
okie dokes....
*teamkrazy heads to the for sale section*
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
