  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I cant believe I am slowly catching chaos, he he he once he starts working he will be too tired to whore :D
plus, if he is shacking up with Ska....they will have to come to some kind of arrangement with the connection...
Hey Ska?? does your dsl modem have an inbuilt switch?
Nope, plus I have a linux box doing the firewalling so I'll just limit his connection speed to zero :D MAMAUaHAHa hahaaH AHha ha ha ha HAAAaaa!!
Plus I do not own a hub/switch dsl modem to linux box then to windows box via cross over so if he wants in he'll have to learn to share, when I am not home, or buy a hub :D Even then he'll wont be able to run a cable out to the garage, it is seperate to the unit :)
don't be mean, how about taking him back to the days of the Commodore 64 mmmmm 6.4K Baud rate modems..... nice
you are a hard man....is there a phone line out there?
dunno what he is bringing, I think he uses the family puter so it'll have to wait when I am not home, cause my puter is in my bedroom, next to bed, (yeah I know what you are thinking, evil discusting men, and yes you are right) so nil access when I am on it or sleeping, which is most of the time I am home :D
Hey im goign to install a HKS turbo timer..
should i buy a wiring harness?
im getting it put in the same time as im getting my alarm so it works in wiht my alarm
so wil i need to get a harness or not?
no
