  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
let me do all the work im capable of on it, from what i here it gonna be a beast, i love helping out on big projects apparently i have forsight (*sp) and this is what keeps me motivated says the shrink i was made to see at school
ah, another trobuled youth. :grouphug:
for sure dude im lookin at doin as much work as i can on it either myself or with mates to save cash.. im hoping in a few years..yes way ahead..that i can post some serious figures
i was an angry child, beat the shit outa too many people so i had to get anger managment counciling hence y i am now so calm and collected and not alot bothers me, my deputy head master used to call me marten briant, now do we all remember y he is famous?
hahahaha, it does actually, i used to do it every sunday morning for like the first 6 months of last year, had lots of family troubles and shiz, and it was how i relieved myself, just the sound of the car at 6 in the morning and the fresh air and the 120...130..140...150.... brake, then out to summerset off the clock for like 5 mins at a time. that was how i used to relieve stress it seriously was better then sex. Hope Kate doesnt read this.
I've really learnt to supress my rage also. I've found that not talking to everyone at work really helps. remember grant me the courage to change the things I can, the serenity to accept the things I cannot and the wisdom to know the difference.
I personally struggle with the second one, as I found myself screaming out my car window today at some F*ck1ng stupid tart who had an "I love animals" sticker on the back of the car but she was smoking with her infant child in the back.
Sweetart, hows about hou stop giving a shit about the animals and start caring for you daugther eh? Man that cuts me up. /end rant
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
