  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
haha true, unfortunately amusement costs money something i am lacking of at this point in time. Receiving packages from japan is exciting, lol although i can never get that ems thing to work for some reason!
