  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hi guys, im about to go ****en jump on a fork lift and tip that f'ckn engine off a cliff, I called DHL and they have no record of parts being sent so unless they used another shipping company other than the one i specifically asked for and the one they told me they normally use neway the parts havent been sent, they havent replyed to my emails for the last few days so i believe i have been rorted of 200 bucks. for **** sake if i new it was gonna be this much trouble i wouldnt of bothered.
Bummer man, hope the parts were sent and this is just a big misunderstanding, hoping........!
Man, spent my lunch reading last nights whore effort, lucky I did, found out SAM (FYN33) IS SINGLE, :) She is soooooo gonna get flooded now, by every single guy here, well the guy that gets to be by her side, is a VERY LUCKY MAN!
im hoping to but i cant see it being feesible, means i have to stay up tonight and try and sort out wtf is going on
Sounds like it might be worth it, also if they start messing you around, call up mindflux and he'll STAB THEM! :) jk mindflux, well he would prolly have the connections to get someone "whacked" over there :D
its nto only that but time is running out to do the conversion, my mechanic leaves very soon and ill be stuck with no money and a half finished car
Hmmm or start saving to pay a mech to do it, just imagine the sound, but think positive, the parts are on the way............. just keep thinking it and it will come true..................hoping!!
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
