  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
John - the lads at aressped are ****ing morons, thank god this will be last time i deal with them
I know this man, this is why there are no more ares stickers on my cars cause they are absolute f[_]ckwits
