  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Not quite sure about clearing the defect but. I'm sure that would go to the owner. Because the owner would have to clear it with the cars registration being in their name and all..
So I think, you get the fine and the point taken off.. and the owner has to clear the defect.
yup......hmmmmmmm......is that how it looks now?
That certainly is how it looks at the moment. You can't notice it until you take a picture of that side with a special type of flash. Like ultra bright or something.
I want to get that all removed and make it look one colour.
Its up to the driver to make the conscious decision that the car is safe and legal before driving it.
We were driving back from gatton when andrew got pulled over for speeding and the copper said "you know that steering wheel is too small and it's defectable. That means the driver Andrew here would get the fine"
I was going to shrug at him and tell him I didn't care, but he probably would have made a fuss about it then. As it was he told us to change it without issueing a defect notice.
bummer....only consolation is that you can't notice it in natural light, but when YOU know it's there it always stands out like a dogs ball whenever YOU look at it
nobody else would prolly see it
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
