  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
bummer....only consolation is that you can't notice it in natural light, but when YOU know it's there it always stands out like a dogs ball whenever YOU look at it
nobody else would prolly see it
That's exactly right. I mean the flake on the roof isn't huge, but I know it's there and I know that it looks terrible.. But others may not notice is :S
I'm pedantic when it comes to my car and everything has to be clean.
He'll be sparkle princess next saturday night :rofl:
yeah....I'm the same...the previous owner has used a buffer on the car or something and from certain angles I can see the marks it has left.....did one quarter panel with meguiars scratchX the other day and it came up a bit better, but the whole car needs a good go over with it.....once again, other people prolly don't notice, but you always notice every little imperfection on your own car
found the rant
hi guys, im about to go ****en jump on a fork lift and tip that f'ckn engine off a cliff, I called DHL and they have no record of parts being sent so unless they used another shipping company other than the one i specifically asked for and the one they told me they normally use neway the parts havent been sent, they havent replyed to my emails for the last few days so i believe i have been rorted of 200 bucks. for **** sake if i new it was gonna be this much trouble i wouldnt of bothered.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
