  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cant wait untill someone reports it then... OH opps did i say that out loud.
omg... you are going to start another war again...
been too many war going on in here....
why cant everyone be like me and matt? peaceful, nature loving ppl?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
