  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
exacery....jsut coz you have a fast/nice car doesn't make you king shit.......I know lots of ppl with fast/expensive cars and who earn shitloads of money but they don't act like they are better than anyone else
aren't they drug dealers or some shit? if you ask me that just makes em dicks anyhow..
http://www.skylinesaustralia.com/forums/at...achmentid=13765
turned out not bad huh?
mmm....looks nice...is the bonnet closing now?
haha.. well some rumours are true :D lol
yeah i got the lid on : http://www.skylinesaustralia.com/forums/at...achmentid=13764
hopefully i notice a difference, otherwise thats $160 gone to waste (yet again)
anybody know whehter the endless pads are any good? that is what i had on there when i first got the car, then my ex changed em over when she got the car defected and whatever i have now is SHIT
hmmm... BDA will be getting a call very soon I think. Can they do all the shit like flush the fluid and all of that as well?
I basically need all that stuff done before i take it up a mountain again..
NFI...but I presume so seing all the services they offer
Give them a cal...the guy was very helpful, especially considering I called him on good friday, and I had called him at his home (I didn't know that...it was just the number on their site)......didn't try to get rid of me or anything, and offered to meet me at the workshop tomorrow:)
I would pay up to $250 for good pads i guess.. the main problem on mountain runs is that i can't throw the r33 into corners too hard.. i'm generally having to take it easy into the corner and shoot it out as fast as possible,.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
