  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Glenn - Do you think nick will take my signature all in good humor or will it be too much, I know he's getting pretty sick of charly taking the piss outta him, so dun wanna push it, BUT IT IS JUST SO DAMN FUNNY!!!
naahhh... he will be fine with it... i had a chat with him abt it... telling him to be open minded and stuffs....
and besides.. i LOVE your new sig ... can i order the kit as well or is it only for the 33s? :D
hmmm havent passed me yet glenn, but as I said to strutto, I AINT GIVIN UP number 2 without a good fight!!
hmm... i only for most graveyard shifts and so long as there's someone for me to whore with ... i give you *mental calculation* another week or so :devfu:
hey guys this got me thinking ...
My best mate back in sydney lost his licence lats night..
he was lost and turned right at a no right turn, the cops got him.
and also pinged him for missin 'P' plates .. and its doubble demerit points
in the end he lost 6 points simply form turning rigth when he should have.
so hes a bit pist off that his whole licence went in one hit (when your on your P2's you have 6 points)
Now I was thinking, If i get done for a few defects how many points do i loose?
see like they could get me for my head light .. (note: cant fix it as the shops are closed)
and lets say they find another defect, (note: i dont know of any others:))
What will happen. like how many points will i loose, 2 per defect?
not sure abt that one, Matt.
No double demerit points in qld.
btw Cyrus, i just wanna comment on you going outa yr way to help Chaos.  I thk its really very magnanimous of you.
Bah I have had the same thing done for me on no less than two occasions in my lafe and it helped me outta holes I was in, just passing on that same opportunity to a bloke that needs it, it all depends on what he does with this opportunity, it's all up to him really :D
yeah... i told him the other night.... to grasp this opportunity ... and not to let you and us down...
hopes he get the message... but i am sure he will do his bestest :D
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
