  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
is it gunna be on the road for the 17th
I would like to think so but it will be tight, gotta do the whole exaust aswell
Eug, yeah man just give me a call ill be working on it all week, ill give u the addy of where were working on it.
Warwick, yeah i though i was gonna get chopped, but he did have all those signs in the back...
