  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
oi, Autoterminal hasnt had a single skyline in 10 months
Ah yeah i remember, call them and ask about it, they were waiting to get compliance plates for them or do the thing so they could put plates on cars
