  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah yeah,
hey ther eis a nice big soccer field behind my house one night we should go grass drifting, thats fun
naah... i'm a plant lover :P
i one of those hardcore parading outside government house with signs that say 'SAVE THE PLANET' !
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
