  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
cool I am down with that :(
it will be my last run in the car as it is now, before the serious work gets
done :D
I want high 13's now, I will settle for low 14's I guess.... then onward towards the low to mid 12's in the next couple of months :)
Oh and Page 666 is owned by Nexus9 aka Satan
He shoots .... he scores
pity they are such a nice car otherwise :(
http://www.fullboost.com.au/racing/dragmee...03_052_014b.jpg
yup..... its got the looks the power and a big dumb broken box...
it will be back on the road in a months time... getting straight cut gears.. hopefully they will hold up longer than the 3000km the last box lasted
http://www.fullboost.com.au/racing/dragmee...052_014b.jpggot
might have to get a DogBox if you start hitting 200KW in the Rex
i have 180kw @ all four wheels now.... i just wanna get a fmic, upgrade brakes and fuel system.. and ill go easy on it from there i thinks
shit how did you get that kind of power without a bigarse FMIC on a Rex???..... almost unheard of I would have thought..... but some engines are definitely better than others on the same car I guess.
shit how did you get that kind of power without the FMIC on a Rex???..... almost unheard of I would have thought..... but some engines are definitely better than others on the same car I guess.
ive had the engine rebuilt. i basically have the same internals as an sti, and i have an sti topmount on it now as well. unichip 3 inch exhaust from turbo back and vf29 turbo.... its running 17psi now.. so i guess if i get the fmic. i can up the boost and get more power easy with out any extra mods..... so im pretty happy with that... just this gearbox giving me the dramas...
aha that sounds a bit more like it, I was beginning to doubt you there for a minute (no offence, you just hear so much bullshit on forums, as you would know)
Good setup and once you get the appropriate box for it you will be giving many a car a bloody big fright .... heheh
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
