Whatever happened to bringing Kim along eh? eh? eh? :(
yeah I don't think that will be happening as my current found out that I had been speaking to her and the shit hit the fan, which is why I have been good and attentive towards her and not whoring here like I want to :D
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
speaking of oil....does anyone elses car chew a bit
mine has never done so up til now, but after last thursdays run it was at hald on the dipstick.
i was sitting on or close to the redline for a lot of that run to hinze, but I've given it that kinda stick before and it's never really chewed any oil.....
yeah I don't think that will be happening as my current found out that I had been speaking to her and the shit hit the fan, which is why I have been good and attentive towards her and not whoring here like I want to :(
OH OH OH DATS BAAAAAAAAAAADDDD!!! Sorry dude, that'll teach you for not handing out her number :D BABabah haha H aH ah hah AHAH aHhaaaa, jk.
So really what are you up to tonight? Seriously, I have not had the best of weekends and am definatly NOT staying in this empty house longer than I need to..................................
my car is havin a tanty cause it hasnt been started all weekend, i bet you it either
a. wont start
b. will start but will run like a bitch for a few seconds
c. cyrus smells
(gotta have the novilty option in a poll)
I choose "D" all of the above :(
Mines never chewed any oil, no matter how much stick I give it, nearly every morning be fore I start i check levels, remains constant 2 mm below full.
a. wont start
c. cyrus smells
C C C PICK C Is C the winner, I BET YOU C IS THE CORRECT ANSWER, hang on a sec, what was the question............ oh :(
cyrus u think ur weekend sucked, can i offer you my stomach bug?
Hmmmm as tempting as it sounds, because I could do with losing a couple of kilos, I think I'll pass, you coming over to Nex's place tonight? You could pass it all on then? :(
chris ur a man whore
lol
warwick chances are you got a lot of blowby when you were running hard up the hill?
high boost as well?
yeah...blowbye crossed my mind...my BOV setting had moved a bit too after that run also
running 10psi
WHOLY CRAP Chaos broke the 2k mark, fark me he's got no life!!!!!!
yeah make sure you allow no internet connection when he comes to live with you Ska
cold the sphincter of the universe is the only option for an addict I am afraid
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
