Whatever happened to bringing Kim along eh? eh? eh? :(
yeah I don't think that will be happening as my current found out that I had been speaking to her and the shit hit the fan, which is why I have been good and attentive towards her and not whoring here like I want to :D
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
speaking of oil....does anyone elses car chew a bit
mine has never done so up til now, but after last thursdays run it was at hald on the dipstick.
i was sitting on or close to the redline for a lot of that run to hinze, but I've given it that kinda stick before and it's never really chewed any oil.....
yeah I don't think that will be happening as my current found out that I had been speaking to her and the shit hit the fan, which is why I have been good and attentive towards her and not whoring here like I want to :(
OH OH OH DATS BAAAAAAAAAAADDDD!!! Sorry dude, that'll teach you for not handing out her number :D BABabah haha H aH ah hah AHAH aHhaaaa, jk.
So really what are you up to tonight? Seriously, I have not had the best of weekends and am definatly NOT staying in this empty house longer than I need to..................................
my car is havin a tanty cause it hasnt been started all weekend, i bet you it either
a. wont start
b. will start but will run like a bitch for a few seconds
c. cyrus smells
(gotta have the novilty option in a poll)
I choose "D" all of the above :(
Mines never chewed any oil, no matter how much stick I give it, nearly every morning be fore I start i check levels, remains constant 2 mm below full.
a. wont start
c. cyrus smells
C C C PICK C Is C the winner, I BET YOU C IS THE CORRECT ANSWER, hang on a sec, what was the question............ oh :(
cyrus u think ur weekend sucked, can i offer you my stomach bug?
Hmmmm as tempting as it sounds, because I could do with losing a couple of kilos, I think I'll pass, you coming over to Nex's place tonight? You could pass it all on then? :(
chris ur a man whore
lol
warwick chances are you got a lot of blowby when you were running hard up the hill?
high boost as well?
yeah...blowbye crossed my mind...my BOV setting had moved a bit too after that run also
running 10psi
WHOLY CRAP Chaos broke the 2k mark, fark me he's got no life!!!!!!
yeah make sure you allow no internet connection when he comes to live with you Ska
cold the sphincter of the universe is the only option for an addict I am afraid
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
