  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Neil, go read up on the Forced Induction Performance and Maintenance threads. They are pretty good though you gotta learn to filter out the rubbish advices by noobies.
In QLD, i know that guys like Strutto, Jay51, Squizz, Slip and JLnewton knows their stuffs. Also, Tze (my neighbour) is pretty knowledgeable as well.
I learn some of my stuffs from Tze and mostly by reading.
The true king in these forums would be 'sydneykid'. he's our god :(
i put in some offers on some second hand ones i found on various forums
sorry.. i forgotten to include these guys in my PM to you. Their prices are VERY good and its brand new from Japan as well. Lotsa guys here are ordering from them as well.
http://www.greenline.jp/
http://www.nengun.com/
13's my ass!! be lucky if i break the 14's!!
running 11psi w/ boost controller.
13 is very possible, Sam.
you have got FMIC, PowerFC and boost Controller. Your standard turbo is good for maybe 1.2 bar. If you got the right traction and launch is properly done. You might just break into the 13s.
sam a lot of Na 33 run 14s you get yours tuned right and u will run 13s easily
ben, that's impossible. NA 33 do not run 14s unless we are talking abt John's car but he's got happy gas.
my car, completely stock, manages only 15.98. i have got a rb25de inside and my car is 100kg lighter than the 33s.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
