  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yep.... guess neil and glenn wont get charged for the dinner this thursday night... :(
nick, i have got 2 exams to sit for. major servicing on your car will take almost a whole day or so. the massive cruise is on sat.
work out the equations. i will do it but not so soon.
i took this picture
wesbank raceway ripped it off my site, cut off my logo and used it, when i saw it i got mad and threatened lagal action,
they gave me VIP pass for wesbank raceway and a link from their site
hahahaha
anyway just thought i would show u my pic
shit.. thats an awesome shot... wat digital camera were you using?? and wat settings were you on? e.g. 200 ISO, 400 ISO, auto, manual ??
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
