  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
HAHAHA omg i didnt tell yous about this dick at tafe, he was going on about his R31 skyline which he just put a RB20DET in, as if he even has it never even drives lol. but he said he just hooked the turbo straight up to the throttle body so he doesnt have to worry about the detonation. i just said mate your a genius
:confused:
Being a noob I have no idea what all that mean, understoon the skyline, r31 and rb25det bits though :)
chris what are you doing to ur car? anything along the lines of what i got planned or what?
very close, I sat down with Gav did a roadmap to follow and we are shooting for 250RWKW before tuning :)
The bits are slowly coming together in my garage as we speak :)
Tomorrow I will be running the car as close to stock as I can get it, so no boost, no revving past 7000rpm, it will be good to se the times it's got in it as is :D
well he said he ran piping from the compressor outlet to the throttle body, didnt put an intercooler in cause intercoolers cause detonation problems LOL!!!!!!!! intercoolers are a prevention
hmmmm you forget NOOB!!!! :confused:
i remember coming back from the coast last nite. CAMERA, FLASH, FLASH! Nexus9 theres a camera! bit slow lol. i bet that damn 4x4 was speeding :| least near yatla i was quicker on the case
Yeah I'm sweatting on dat, hopefully I was behind dat 4x4, they are usually pointed at the outside lane, so I prolly set it off, dunno who is going to cop it, prolly either Nex or me or no one :)
120 in 110 is only like $90 and 2 points though ;( still cameras SUCK!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
