  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Belg and Nex will be quickest...
Ska and me will be next...
MJ will be last :)
Warwick will probably wimp out...
NO SKA WILL be last, I am ALWAYS last, got used to it though :D I tend to pick on cars I know I can beat, like falcodores :)
MJ will be last :)
lmao...If I can muster up the funds.....I will prolly run a close last :D
today has kinda drained my funds....but the missus' credit card is in sight :)
Yeah I did have 2 passengers, 3 jacks and a big ass backpack in the boot :) well I am using that as an excuse, not the lack of a decent exhaust, fmic, ebc, etc etc etc
I had my golf clubs in the back, does that count? :D
Hey JL you bringing out the gtr to play tomorrow night??!?!
Yeah, I was going to bring the GTST but the GF using that at the moment so I would have to wait for her to finish work. Would be nice to lay down some times while the GTR is still stock.
I am running as close as I can to stock tomorrow, so Ska may beat us all
ABBABAhbah ahaH ha h Aha haH aH aH aH aH ha aaaa :) maybe in a couple of years when I eventually stop hitting traffic islands and am able to afford a exhaust, but by then everyone will prolly have GTR's :D
Yeah bring it on out, I want to see it in action :)
