  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
what's an 'auto shift kit' ?  is it one of those + and - thingy?
That is a squential gearbox, blagh I hate them, good for quarters, but daily driving, I got from 3rd to 5th and from 2nd to 4th a lot, cant do that in squential directly have to manually go through the gears.............. :P
Increases the line pressure in the automatic by changing the valve body...  Means less slip on changes meaning more time getting power to the ground... Installed one on a V8 Soarer that is coming tomorrow night...  Found a supplier in SA who does them for around $400...
ok. thks. learn something new again today.
never heard of those things till you mentioned it.
