  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Fluid?
Belt?
re the Power steering: When parking the car at low speed and revs (ie at about 800 revs) the power steering is almost impossible to move at all. If I rev the car to about 2000 revs the power steering magically decides to work. ALso I checked the fluid levels and they were pretty low so I have topped them up. I'm thinking it's the belt. Opinions?
If the belt is still there, it should be fine...
Plenty of fluid... Sounding like pump unfortunately... :)
