  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Well I cant really say, was definatly more than one ;) but we were all really close and i _hope_ i was actually behind the 4x4, which means Nex is gonna cop it ;) Sorry bud!!!!
Oh well .... hope they got my good side :)
