  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Well I cant really say, was definatly more than one ;) but we were all really close and i _hope_ i was actually behind the 4x4, which means Nex is gonna cop it ;) Sorry bud!!!!
Oh well .... hope they got my good side :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
