  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
james im hoping ur racing?
but you could wear ya flannies and thongs and a vb singlet and im sure some of the v8 owners will offer you a beer
Nah I've never been to the drags before. So I'm going to see what It's all about. Maybe next time. Plus my power steering went spaz last night. Should be fixed by this time next week tho. :D
only if it is long sleeved ;D
no I's a short sleeved one. But if I wear something with long sleeves underneath it...... And I can dig up those stonewash jeans of mine that are so tight they bareley fit anymore. I'm thinking If i do that though I'll be in for some meat and two vege tonight. owwwwww.
think there were about 8 racing amd a few others spectating
good SAU representation overall
there was one guy there in a silver 32 that I went up against in my last run who had an SAU shirt on....I don't think he was with us though...maybe someone else knew him
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
