  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I just had a shower :P
Your exactly right Warwick. No point denying stuff and acting like a knob because it will just infuriate the copper and make him want to actually book you. But if you act all sincere and admit to what you were doing, they sometimes let you off and sometimes give you a lighter fine than what you were meant to get :)
:Oops: not big noteing my self but this time around :headspin: I have held my licence for over 2 years & never lost one point but mind you I am on my third go & if I lose it this time thats it it's gone for good :Oops:
hey neil so how much can you get the drift wing for?
not too sure, will have to call jetspeed and ask,
my brother is thick up there, we basically get trade prices on all kits using dr kustom provided we use them to do the spray work on the kit parts
they really cheap for spraying stuff aswell, and work is really good.
they gonna do a pearl flip with glitter over my brothers black lancer for about 1300$
sweet boet, im looking at a kit and respray soon, so can you get the 400r kit through jetspeed? if so you know how much im looking at?
