  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ok so if i go out and buy sickaflex and just use that to attach the wing it will be fine? I just spread it evenly under the wing and attach it to the car? and dont have to worry about screws?
If i decide to pull it off will it cause any damage to the paint?
Thanks all :P
u wont get it off teh paint, unless u angle grind it off :)
sikaflex is black
and we held the front bar onto a mates strawberry face 180 with that stuff
once it dried, it never fell off (to my knowledge)
Yeah just becarfull what type of sikaflex u get there are a few types because some do not set fully they stay soft :P
Teamkrazy my wing didnt come with the nuts embedded in it :P
i can see myself ****ing this up, so i might just goto a panel shop tomorrow and get them to fit it, this is the type of thing where i only have 1 go to get it right.......
try cut some screws and screw them thro the orginal holes and into the wing, and back that up with some mirror tape
i dont think i met you last night teamkrazy, i was cruising back from fingal with you, i noticed you still had your number from willowbank still on heh
nice car man
lol yeah i could not walk yesterday (wakeboarding killed my knee) so could not clean it
thanks for the comments :-) i remeber you next to me a few times, i dig the bonnet
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
