  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ah yeah I think we did just befor every one left for home we u were standing beside me with erin & a few others right?  :P
is that your car in the avatar?... saw some very nice 31s yesterday... SIR31 was mad and loud!! :)
lol... yes i did sir....
what can i say?.. only in chinatown warwick... only in chinatown :P
but its good to see you enjoying your dish.  i was praying that you were not sadden and grumpy abt what happened....
yeah...food was great...wasn't too depressed last night, but I have been getting a bit that way today....I spose it will be worse when I have to actually pay the fine and hand over my licence:(
