  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nah.. guess i'll call him friday and ask (when he said it would be back). I'm sure it will be "we've been really really busy.. its going to be another couple of weeks".
Guess not too fussed, the longer it takes the longer i have to save to pay for it.. and get ready for the $800 for the timing belt and things after that. Money money money is so funny, when you're burning it all away..
Just called Don from DMD... My bar is ready :D
Will pick it up on saturday hopefully if my car is all good again....
Glenn do you think Don will be able to fix my Top secret front bar...? I found the long lost 4th peice of it in my garage... I forgot I even picked it up after the accident... And I think there may be a chance he could make a mould out of it... hmmmm
not likely though. had a similar request once from my mate. he wanted Don to fix up his 180sx front bar but Don said something abt it may not hold or might as well get a new one.
Yeah exactly, I mean make a whole new mould from it... he asked if I had all the peices when I first went there... now that I have all the peices it may be possible...
I know the feeling, strange how one small island can take away my 3 inch exhaust turbo back :D
Yeah, bloody incidents like a head on with a pole...
lol
I mean ive spent over $4k so far sadly after that ;) and then add to that the bill to fix the engine goings on and a new clutch...
if they can make a mould, shouldn't matter if its in a couple of pieces if you can sorta temporary stick them together..
should be jumping at the chance.. usually these body kit places have a shithouse selection of kits to choose from..same old
hmmmm Im looking for some part time work so I can leave my current job and have money coming in so I can study for my full license...
If anyone knows of anything going let me know :D
Gordo, your dead right, they can patch it up then make a mould.... and sling me some cash from being able to copy a rare front bar...
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
