  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
OMG NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
CRAP CRAP CRAP!
This sucks!
http://pub49.bravenet.com/faq/show.php?use...8552&catid=5#q2
Was Tripitaka a boy or a girl?
If I had a penny for every time someone asked me this question, I'd be a rich man! To set the records straight: The character of Tripitaka was MALE (a boy priest) The person playing Tripitaka was FEMALE (the Japanese actress Masako Natsume, who tragically died of leukaemia several years after making Monkey.
So the character was male but the actor was FEMALE
AND SHE IS HOT
http://www.monkeyheaven.com/masako.html
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
