  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
It's not difficult. To make a woman happy a man only needs to be :
1. a friend
2. a companion
3. a lover
4. a brother
5. a father
6. a master
7. a chef
8. an electrician
9. a carpenter
10. a plumber
11. a mechanic
12. a decorator
13. a stylist
14. a sexologist
15. a gynaecologist
16. a psychologist
17. a pest exterminator
18. a psychiatrist
19. a healer
20. a good listener
21. an organiser
22. a good father
23. very clean
24. sympathetic
25. athletic
26. warm
27. attentive
28. gallant
29. intelligent
30. funny
31. creative
32. tender
33. strong
34. understanding
35. tolerant
36. prudent
37. ambitious
38. capable
39. courageous
40. determined
41. true
42. dependable
43. passionate
WITHOUT FORGETTING TO:
44. give her compliments regularly
45. love shopping
46. be honest
47. be very rich
48. not stress her out
49. not look at other girls
AND AT THE SAME TIME, YOU MUST ALSO:
50. give her lots of attention, but expect little yourself 51. give her lots of time, especially time for herself 52. give her lots of space, never worrying about where she goes
IT IS VERY IMPORTANT:
53. Never to forget:
* birthdays
* anniversaries
* arrangements she makes
HOW TO MAKE A MAN HAPPY :
1. Shag him
2. Leave him in peace
1. a friend
2. a companion
3. a lover
4. a brother
5. a father
6. a master
7. a chef
8. an electrician
9. a carpenter
10. a plumber
11. a mechanic
12. a decorator
13. a stylist
14. a sexologist
15. a gynaecologist
16. a psychologist
18. a psychiatrist
19. a healer
20. a good listener
21. an organiser
22. a good father
23. very clean
24. sympathetic
25. athletic
26. warm
27. attentive
28. gallant
29. intelligent
30. funny
31. creative
32. tender
33. strong
34. understanding
35. tolerant
36. prudent
37. ambitious
38. capable
39. courageous
40. determined
41. true
42. dependable
43. passionate
45. love shopping
46. be honest
47. be very rich
* birthdays
* anniversaries
1. Shag him
:werd:
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
