  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey all.. don't you ****ing hate slow computers?! shitting me right up the wall and slowing down my whole work :D you kinda need a decent computer to have photoshop, dreamweaver, IE, outlook and illustrator open at the sametime! then again that is their problem rather than mine i guess. I still get paid :(
James :wavey: yeah glenn is picking me up, but he doesnt have my address as yet, lol
My car need severe mental help! You coming out tonight?
Let's do a count. People who have posted on this page allready who are waiting on cars: ALL.
Yes Mines still in the shop and I "should" have it back tonight. If I do I'll be out. If I don't I'll probably have a V6 Auto commodore with work plates on it. So I'll also be probably coming out.
If I don't have that I'll be driving a van, in which case I won't be coming out. :D
*prays for car to come back today*
anyway for those that weren't listening to triplej 2 mins ago..
there was this guy who borrowed his mates BMW then said it was "stolen". He got it resprayed, then a few weeks later showed it off to his mate "hey look man i got this cool new beamer now too".. of course his mate worked it out pretty quickly, and he was busted.. :D he was a muzza from the sounds of the name too .. :(
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
