  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
]Are you serious???
__________________
...what's a Cefiro?
Notice my initial suspicion?
you guys made this all up last night as you were bored, you are going to post another 3 pages of crap perpetrating your story
:mad:
ha.. well put it this way.. if there was a group of skyline owners.. the cops happened to note "skylines australia" on the cars, and this is later used it court as being "being involved in an organised activity" or whatever it is classed as. Its not the best.
Another random time a copper pulls me over, or happens to come by another meet like the other week.. notices that I am a member of "skylines australia" the one he booked those guys for recently for this incident. He may take rather unkindly to me, or others from the get-go.
You bit hard... Take it like a woman!!!
:mad:
.. but it is something i could imagine happening to him actually.. :rofl:
see if you had said strutto or yourself and hit the car i probably wouldn't have believed it straight away.
HEY!!!!
I take offence to that remark :mad:
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
