  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah I'm well impressed with the N/A-turbo thing, people are just too ***** to try things these days.
When the Z finally makes an appearance...I've got the nice bolt-on Trust kit in my sights :D
I'll lower compression on this one though and go for some more serious boost.
Kit inlcudes:
Turbo TD05H-18G (x2)
Cast Manifold (x2)
External Wastegate (x2)
Pre-programmed E-manage
440cc Injectors
And all the other odds and sods for US$4995
Definately looks interesting ;)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
