  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i am talking 93 or 94 model.. i have been looking on yahoo auctions for a bit of a rough indicator.. 400 - 600,000yen.
of course 1997 or so above they jump WAY up.
But the earlier ones seem to be around the same price of soarers.. and soarers i am sick of seeing, too many around.
but i am going off yahoo auctions and whacking $7k ontop for landing and compliance.
Its the best i can do to get a rough guide at the moment.. if its too expensive i wouldn't bother. may as well just keep the R33
They are twin turbo yer, same engine as soarers, which have modification potential.
http://www.alljapanesecars.com/viewcr.php3...r=1994&mc=JZX90
here are the specs, etc.
Eug: You might be talking about 1998 or later models. They are around the $1mil yen mark, which i guess would work out to be $20-$30k i guess
it would be something different, no dont see too many around, and plenty of 1jze-gte engines itn he soarers for parts.
Its possible compliance isn't available for earlier models. If that is the case :(
but something i am thinking of.. i have been thinking 1989 GTR and RB30 bottom end, and full rebuild -- while could end up under $30k for a 11sec GTR.. i really need something cheaper.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
