  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Whenever I have to go into brissie I catch the 30 min express in, cant beat it, for $10 I get into and out of the city in 30 mins flat!
+ status is given as soon as I can rekognise your face, so once we meet a couple times :( maybe :)
for me its $10 petrol (r31 though) a day.. and 50 mins door to door from my house to umart front door.. guess its fairly similar.
hmm, well if nobody is up for anything tonight, i may just go down the video shop and grab something.
yeah, me too.. that is why i was asking whether anybody wanted to do anything. Don't really have too many ideas though..
if i had the r33 i could go do some drifto sessions.. the r31 can get me somewhere, but it won't be very fun.. rally? :(
kill bill vol.1 is good.. some reckons its bettter than the 2nd.. haven't seen the 2nd myself yet though.
really - so the cops scoped em out or something? glad i wasn't there, wouldn't want to deal with that shit right now :( i got enough crap on my car i have to worry about doing, nevermind clearing defects.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
