  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
u live @ G/Coast Cyrus... come to Bris and u can watch with the blue.
and i can get that +. Win Win.
Hmmm my kids are asleep, so you want me to potentially wake them up, pack a bag for them and put them both into the car, drag my sorry ass up there just to watch a video, bah I'd rather watch in with the blue :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
