  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ahh.. ok thanks:wavey:
gratz on the job offer... any job is better than maccas..
then u can get a skyline with that kinda money :)
hmm..
Some experts say the flutter of a butterflies wings can cause a typhoon around the other side of the world
i think thats the butterfly effect, not chaos theory :(
