  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Skylines Australia Discussion Forums's Store
Welcome to Skylines Australia Discussion Forums's Store, More welcome text to go here!
Quick Nav - [Purchase History]
Change Custom Title - Change Other User's Custom Title - Change Username - Glowing Username - Colored Username - Bold Username - Italicized Username - Secondary Usergroup - Sticky Thread - Thief!
Quantity: 19 Donate
Imput Username Who would you like to donate to? Imput Ammount How much would you like to donate?(Remember, 2% tax.)
This will take you to the confirmation page.
yeah James i know him, he's this real little geeky guy that i used to go to school with and looked up to me so much that he bought an NA 33 just to be like me!
Umm im leaving at like 4ish tomorrow arvo.
ok just tell him that we're going to have to smash all of his copies of the fast and the furious before he can talk to us. :rofl:
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
